TTI headers sensor bung location
Small Block Mopar Engine
  1. BVoelzke
    BVoelzke Dart Racer
    212
    224
    Aug 23, 2009
    North Jersey
    Local Time:
    1:41 AM
    Anybody have TTI headers with the bungs installed for O2 sensors ? I just got my new set this week and am not happy that the sensor bungs are on the outside of the collector, I wanted them on the inside so you don't see them. The dealer I bought them thru is looking into it on monday. Is this were TTI puts them on all of their headers?
  2. JoeSBP
    JoeSBP RLTW!
    1,230
    662
    Jun 16, 2015
    NC
    Local Time:
    1:41 AM
    I would have gotten no bungs in the header, then added a bung a few inches after the flange..
    • Agree Agree x 3
    • TrailBeast
      TrailBeast AKA Mopars4us on Youtube
      21,264
      8710
      Mar 11, 2011
      Arizona
      Local Time:
      10:41 PM
      Me too, oh wait I did. :D
      Facing the bell housing and up at a 45 angle on the inside of the pipe.
      After reading a LOT about the A/F sensors and placement I used pipe color to determine where to install the bung.
      Different discoloration of the exhaust tubing relates to different temperatures and the sensors like to be within a certain range of exhaust heat to read correctly.
      It's not super critical or anything, but if it's a choice it might as well be in a good functional position.
      In my system it was right after the collector flange.
    • BVoelzke
      BVoelzke Dart Racer
      212
      224
      Aug 23, 2009
      North Jersey
      Local Time:
      1:41 AM
      Thanks for your opinion but thats not how I want my system, my old Tubular Automotive headers with the sensor bung in the collector, ON THE INSIDE worked fine.
    • JoeSBP
      JoeSBP RLTW!
      1,230
      662
      Jun 16, 2015
      NC
      Local Time:
      1:41 AM
      To further state my opinion, I wanted the bung after the collector so if I ever sold them, it wasn't with a hole drilled in them, and the sensor was reading off the full bank.
      And to answer your question, yes it does look like the default install position from TTI is on the "outside" of the collector..
    • BVoelzke
      BVoelzke Dart Racer
      212
      224
      Aug 23, 2009
      North Jersey
      Local Time:
      1:41 AM
      I know after reading their catalog closer I screwed up I didn't read the bung installation option close enough. I am
      Going to try and return them but since they were special order I may not be able to , have to wait and see what the dealer can do, they might end up for sale in the parts for sale section
      • Disagree Disagree x 1
      • 72Dart6pack
        72Dart6pack Well-Known Member
        3,533
        3079
        Feb 1, 2016
        Roseville Michigan
        Local Time:
        1:41 AM
        Did you not read info on the TTI site before you ordered?
      • Needswork
        Needswork Well-Known Member
        59
        15
        Oct 20, 2015
        Northern CA
        Local Time:
        10:41 PM
        I have the 1 7/8 race headers, small block, A-body. I think the part no is 34017835. I can confirm that the O2 bung is on the outside for these. I also thought the positioning was not ideal.
      • rod7515
        rod7515 Well-Known Member
        1,592
        462
        Jul 18, 2013
        Red Lion PA
        Local Time:
        1:41 AM
        TTI was very good to work with when I bought my headers. I had ordered the wrong size collector for a 2 1/2" system but was going with a 3" system. When I called they had me send the incorrect ones back and then sent me the 3" all within a week. No additional charges so Im betting you will be taken care of.
        Best of Luck
        Rod
      • JoeSBP
        JoeSBP RLTW!
        1,230
        662
        Jun 16, 2015
        NC
        Local Time:
        1:41 AM
        I know they are "special order", but since it's a standardized option, hopefully they will take them back. I know it can be frustrating when you drop some cash, only to realize it won't work
        good luck!
      • BVoelzke
        BVoelzke Dart Racer
        212
        224
        Aug 23, 2009
        North Jersey
        Local Time:
        1:41 AM
        Thanks guys, the thing is I hardly pay attention to the sensor gauge as I am mainly focused on driving and going rounds. I probably could have done with out the bungs altogether.
      • fratzog lover
        fratzog lover Well-Known Member
        13,564
        11080
        Jun 7, 2013
        Maple Shade New Jersey
        Local Time:
        1:41 AM
        Big cash when it's TTI !
      • famous bob
        famous bob mopar misfit FABO Gold Member
        16,159
        6069
        Aug 14, 2011
        okla
        Local Time:
        12:41 AM
        ----------THIS , is what fast recommends for bung location, supposedly won`t give a full 4 tube reading if that close to tubes.
      • hotrod360andy
        hotrod360andy Well-Known Member
        144
        61
        May 25, 2015
        Minnesota
        Local Time:
        12:41 AM
        I would not expect them to allow you to return them but if they do....then say thanks for the great service even though they do not have to do that. Been running my tti's for about 10 years now on my big block duster drag car. Fitment has been great, they are getting scratched up from taking the engine in and out every season but the quality is great. Love em!!
      • BVoelzke
        BVoelzke Dart Racer
        212
        224
        Aug 23, 2009
        North Jersey
        Local Time:
        1:41 AM
        I kept them and put them in last weekend, they fit well, I had to modify my shifter cable hold down but other than that it went well, I was able to get rid of the 90 degree filter adapter which always seemed to leak. I just had it running a little while ago and everything sounds good no leaks. They do fit close to the trans pan which is now i see why the bungs are on the outside but they fit up in the car tighter so you can`t even see the bungs/wires.
      • hotrod360andy
        144
        61
        May 25, 2015
        Minnesota
        Local Time:
        12:41 AM
        Awesome! Glad you like em!!!
      • sireland67
        sireland67 Well-Known Member
        8,936
        3091
        Oct 27, 2010
        WV
        Local Time:
        1:41 AM
        You could always put a plug in them and weld a bung wherever you want.
      • BVoelzke
        BVoelzke Dart Racer
        212
        224
        Aug 23, 2009
        North Jersey
        Local Time:
        1:41 AM
        My old headers had two bungs because I used to have a FAST system using both bungs I sold the system and now have a gauge and am only using one bung on my new TTI s and have a plug in the other. I was worried about seeing the wire but since they are installed in the car they fit up in the car more and you can't even see the bungs/ wire.
