moparspares
If you are using a Magnum block with TTi headers you will have to grind some of the rear magnum passenger mounting pads on the block. I had to take approx 1/4 inch from mine so the headers will sit flat on the heads.
There is no info from TTi about this prob when they sell these. Luckily this was spotted while I had it all assembled on an engine test stand and not in the car.
Just FYI
Just FYI
