skep419
No show, all go!
I really don’t understand what you’re getting at.
No, the car should not be sitting on the bump stops at ride height. That would mean your suspension is bottomed out at ride height. You should have a couple of inches of clearance between the UCA and the upper bump stop and the LCA bump stop and the frame at the factory ride height.
If your car is at ride height in all of the original pictures you posted, then your car is lower than stock. If the caliper is hitting the UCA at ride height by turning the steering wheel that’s a complete screw up, that should have been identified when those parts were installed. I assumed the last picture was with the car up on jacks, so that the suspension would have been sitting on the upper bump stop. I couldn’t imagine that was happening every single time the wheel was turned without it being noticed before now.
you under estimated my lack of intelligence. Car was at ride height for all pictures. Hence the bump stops were the least of my problems.
