Tunnel ram linkage
If you run the setup that old man mopar shows a stock throttle bracket works. It works because it can pull off the bottom of the vertical rod which allows the cable to be almost horizontal. Least thats the way i remember it from years ago. Still run a tunnel ram on the street with side saddle carbs. I like em.
Pictures please !? We like to see that kind of stuff :burnout:
