Tunnel Ram Linkage
72ScampTramp
Scamp Tramp
Fort Dodge Iowa
I have a Weiand D port intake for 440 with dual 600 holleys. What linkages are you guys using for yours? Ive seen a few tunnel rams on here. Photos would be great.
im running an eddy street ram with dual 500 afbs.(i was running holleys)im using the lokar cables/bracket and its run to the front carb.the cabs are linked together by a solid rod with bushings in the large hole in carb linkage arm.you can see pics in my photo gallery.it may not be the most trick set up but it works good.
Since I just purchased a tunnel ram I've been looking at linkages myself. Jegs has some reasonable priced stuff for both inline and sideways mounted carbs.
