Turbo Kit, Motor, Trans...
dart360swinger
Boosted
Okinawa, Japan
Rating - 0%
0   1   0
PARTING OUT turbocharged 360 small block dodge. Only around 1,000 miles on current set up. Email for more pictures or questions. $4000 for everything. Pick up for larger stuff. Nampa, ID 83686
Turbo Kit $2,200
Garrett GT32 variable geometry turbo
304 stainless shorty headers with 3/8 flanges
2 1/2" exhaust piping from headers to turbo
3" down pipe
3" aluminum intake tubing, all mandrel bent pipe
18" intercooler
38mm waste gate
38mm blow off valve
Spectre carb hat
all exhaust connections are v-band clamped for higher pressures
Short Block $500
1972 360 0.030" over bore
stock crank and rods reconditioned
ARP rod and main bolts
Speed pro hyperutectic pistons
9.3 to 1 current compression ratio
Lunati VOODOO cam .474/.494" lift 268 advertised duration
Milodon street 7qt oil pan. -10an fitting welded to side of pan. For A-body
Intake Manifold $165
Edelbrock RPM Air Gap
Cylinder Heads $300
cast iron "J" heads
2.02 in 1.60 ex valves
Lunati VooDoo springs
mild bowl porting
Stock stamp steel rockers
Carburetor $300
750 cfm
Holley 4150 Double Pumper
modified for blow through
Transmission $450
Small Block 727
2200 stall converter
Deep "tube cooled" oil pan
Shifts great.
Came from 3500 van with very low miles
Like New Mallery Unilite mechanical advance distrubutor $200
This was just a recent purchace
Only around 200 miles
Comes with recommended voltage spike protector
No ignition box required
Why the sale? Sounds like a high 10 sec. setup in the right car.
I'd like the heads. What chamber size are they?
Well I've given up trying to sell everything a whole. Here's a few pictures of the set up out of the car.
