christopher.brandon
Just a helpful hint:
A couple months ago I ran into an issue with the turn signals on my 74 Valiant. My 4-way hazards would work, but I got nothing from my left and right turn signals. I found a flasher unit right below the steering column, changed it out and nothing happened, I changed out bulbs left and right making sure the circuit was complete, etc. After days of scouring the internet to look for this mysterious, second flasher, I finally discovered that it was located on the passenger side of the dash, mounted on the right-side of the stereo. So if you are ever perplexed because your flashers are inop, but cannot find the flasher, check there.
Just wanted to pass that on. Hope that helps someone! :thumbup:
-Chris
-Chris
