Turn Signal Issues?
73'-318VALIANT
Terd Slinger
Weaverville, N.C.
:angry4: Ok, the front left turn signal and the fender signal are not working, the right hand side works great but the left front wont blink. the rear signal will come on but stay constant (wont blink). Ive checked the wiring and found no dead wires, but it seems like the circuit is not complete. And yes ive changed the bulbs! lol any help would be great!
Check the front lights to see if they get power if they don't, work your way back to the firewall connector, still no, go on the inside of the firewall connector, still no, then the turn switch is probably dead on that circuit. The front is isolated from the back because of the brake lights is why the front can die but the back still has power. The reason the back won't flash is the stock flashers will tell you if a bulb it out by not flashing, it was Mopars way of warning you of a problem.
Make sure you check all of the connectors in the path it is usually bad contact in a connector.
Chuck
