slantsixdan
Got a couple of seldom-seen factory metal fan shrouds for sale. Both are for '65-'68 cars with the 22" wide radiator (not for the narrower 19" radiator with the wide bracket on one side). One is for use with Slant-6 engines (fan circle offset to one side). The other is for use with V8 engines (fan circle centred). Both are in very good condition with only very light surface rust that will easily clean up. They look a little wonky because the top and bottom rounded parts are springy and want to push the shroud out of a perfect box shape until its two halves are firmly bolted together (I'm missing one nut on the Slant-6 shroud—standard hardware store item) and the shroud is installed on the radiator. I don't have the brackets, which are available new.
$49/ea plus the postage from Seattle, WA, USA—send me a PM.
