[SOLD] Two Edelbrock 600 carbs + jet kit + two fuel lines!
Brooksville, KY
Moved up to a bigger carb so hear is my "experimental" 600 and parts carb.
The good carb is a like new 600 manual choke Edelbrock AFB. This is a very low miles carb. I took the top off of the older carb and machined off the choke tower, and modified it for duel feed. Lightened the secondary weights. And installed stops to replace the linkage that ran over top of them. This baby works great!
You get everything in the pic. The good carb, parts carb, duel feed fuel line, single feed line, jet kit with an extra set of step up springs, a Chrysler lever adapter, and a pack of top cover gaskets. And the 600 parts carb.
Not going to do me any good sitting around going to waste.
All for only $200 plus shipping.
Yea,
I could not see it sitting on a shelf going to waist. Figured I would give some one on hear a deal and send it down the road to some one that could put it to use.
Will be listing a box of thermoquads I have when I have the chance.
