Two speed wiper motor question
dale_brennon
Louisville, KY
I picked up a two speed motor from advanceauto for my Demon, I was curious as if I could run an aftermarket 3 position toggle switch to control the motor, and if does anyone have a part number of the one they used? In addition, what would be required to connect the switch to the motor, would it simply be wires to the motor, or would you need a relay/fuse in between the two.
