Their usually the same size. Almost all A-bodies used the smaller 7260 U-joint. If their not the same size measure and post the width of each. You'll probably need a shorter driveshaft cause the 8-3/4 pinion yoke sticks out farther. You don't want to bottom the driveshaft yoke in the trans. or you'll destroy it.
