under driven pulley dealer
slowdown
colorado
I'm not in the market at the moment, but does anyone know where I would be able to get different sized crank driven pulleys for a small roots style supercharger? I looked around on the web and have'nt come across any for moper small blocks. I talked to one of the guys from this site at a car show this summer and he had mentioned a place in Denver but I don't recall the name of the place he had mentioned. Thanks.
925. 6713 I know this is for a Chevy, but seeings how mopar doesn't make these are Chevy pulleys used an re drilled?
What small super charger do you have?
I have a new never out of the box long nose 144 set up for a Chevy that I could pull the pulley out, measure the overall distance and compare it to a small block Mopar dampener.
As long as you had a Mopar one to compare the length with.
Mine is a 10 rib.
Are you looking to slow it down, speed it up, or just experiment? Does the manufacturer offer some different size top pulleys? I'd think I'd look there first.
Mine is a 10 rib.
My lower pulley is a 6 inch pulley and my upper pulley is a 3 inch pulley. Measuring it from the back to the front of the lower pulley it measures 2 1/2 inchs. But it has a spacer between the lower belt drive pulley and the drive pulley for the supercharger I will have to take it apart to get that length. My nose coming off of the supercharger is something like 10 3/4 inches or close to it. I was given some measurements to determin what supercharger I had by the distance between the bolts that hold the supercharger down to the intake. An according to the measurments I have a 162 B@M. It's an older supercharger, it does'nt have the sight glass for oil level it's the allen head plug.
I think a little experiment, I just got it out for a couple of test drives and it definetly has boost I have'nt figured out how much just yet and I do intend to figure that out before I do anything to aggressive. You, know I have just been looking online for makers of pulleys, I did'nt even think to check manufacturer. I did'nt think B@M was in business anymore. I'm not going to get one right now, I wont be driveing my car till this spring I'm just trying to get it all up and running again after the supercharger installation. But when I go to buy one I would just like to be able to find one.
Here is what I measured using a tape measure instead of a caliper.
The snout on mine is 10 3/4" inches long to the end of the pulley.
The lower pulley is only 1 13/16 inches over all in width. The part number of mine is 93352 it is a 10 rib 6" pulley.
I think you could modify a Chevy pulley to work on a Mopar because it is basically just the pulley ribs and a small snout sticking out the back. The crank bolt is tiny on a Chevy, so the snout could easily be milled off and make a spacer to make up the difference.
I also checked a Mopar lower crank pulley and there is plenty of material to drill it out.
Chevy only used 3 bolts to hold on their crank pulleys.
Also you can buy the upper pulley in a lot of different sizes from Weiand which is now manufactured by Holley.
Holley bought Weiand and B&M out.
I hope this helps.
I hope this helps.
Thanks, it does help.
