Unsilenced air cleaner question
Kenflo
Saint Albert
I am wondering how an unsilenced air cleaner works? The silenced type have snorkels which will pull fresh air in, how do the unsilenced get air in? Through the breather tube? Just wondering if someone could give an explanation on how they work. Also from a performance point of view, would an unsilenced be a better performer over a silenced?
...............The unsilenced pulls air in from all around..........usually more power.........if ur jetting is on, as it may b 2 lean, u may have 2 jet up..........
The base diameter is smaller than the cover's diameter, which leaves an opening all around.
For a cheap (no cost) unsilenced air cleaner....
Remove lid
Remove filter
Take old fan belt and cut it
Lay old fan belt on top of filter
Cut old belt to same circumference as filter
Tape both ends of old belt together
Lay old belt in bottom of air cleaner
Lay filter on top of old belt
Reattach lid
You now have an air cleaner that will almost sound like you left the
lid off for that 4 bbl. moan but all the air will be filtered and only a keen eye will see the lid is 1/4 inch higher than the housing itself.
My old man never found out. I actually glued the belt to the bottom of the lid.
