US Car Tool
63SplitWindow
Montgomery County PA
I'm in the beginning stages of a hellcat swap for my Dart. I'm thinking the way to put this motor and trans in the car will be with the K member from the bottom so I was looking at the USCT K member stand at Carlisle and it looks perfect for the job. As good as it looks, I really can't justify spending $700 for a tool I will use once then take up valuable space. Any chance someone out there would rent/loan one for a few months? I can leave a deposit and pickup/return when done. I'm in southeast PA near Philadelphia if anyone is close.
Thanks,
Bill
I made these 1 for removing the 5.9 magnum with 46re trans, 1 for the gen 3 hemi with tko 5 speed.
It was the easiest engine/ trans removal I have ever done.
3 harbor freight furniture dolly's per engine/trans.
Yep thats what i am doing for my one, doesnt need to loom pretty given its used for a whole ten minutes. Did think of making a steel one that comes apart, but given i am a builder and its literally scap timber having to remake it down the road isnt time consuming or costly
I build mine very similar to Cudafish's above. scrap wood and a cart, easy to store when you are done.
Menard's furniture dollies have larger diameter wheels/better casters. It may be an issue if the floor you are using them on is not smooth. just something I found out in my garage that is, shall we say, a bit needy in the smooth department.
