zhandfull
When I pulled apart this 273 motor it had no oil pump gasket. I'm pretty sure it had never been apart since it had a stock bore and rope rear main seal.
New oil pump has a gasket should I use it or just reinstall without?
At work one of our Ford 460 trucks doesn't use exhaust gaskets it's just a metal on metal machine finish and doesn't leak a bit. So I'm thinking the oil pump may be the same on these small blocks.
