As the title states, these are used chrome factory OEM for 1968 383 engines. I have cleaned them up best I could so you can see the problem areas.
Not perfect by any means with a little bit of surface rust, some of the wire clips half broke off, etc.
No cracks around mounting holes, these are solid used pieces that could be used as is or re-chromed to make an excellent set.
$150 plus shipping & fees.
