I have for sale a used Pro-Race street harmonic damper for the 318, 340 or 360 engines. This is the Pro/Street damper that came off of a 318 LA engine. It’s for use on engines that have the timing tab on the driver side. It is a street balancer and is not SFI approved although it is much better than the OEM pieces.
24278 Pro Race Pro Street Harmonic Balancer, Chrysler V8 318-360
This balancer by itself is for the 318/340 internally balanced engines but I am including the offset weights so it can be used on a 360 LA or a 360 Magnum. I don't have the weight for the 73 externally balanced engine. The hub has no groove in it from the front cover seal. It is degreed from TDC to 60 degrees every 10 degrees with 2-degree increments. This balancer was only used for a short time and is in excellent shape. The rubber elastomer is perfect with no issues at all. It’s very clean and has a coat of primer on it for protection and allows you to paint it whatever color you like. I would like to get $45.00 for the balancer and weights plus the shipping.
Ken
Edison, NJ
Ken
Edison, NJ
