I have for sale a used set of 2.76 fine spline gears for the -489 8 ¾ center section case. These gears are in excellent shape, have been cleaned and carry a 4-10-73 date. The teeth on the ring gear and the pinion gear show great wear patterns as they were set up originally from the factory. We took them out to put in a set of 3.23 gears. Also included is the pinion nut and washer along with a new Ratech crush sleeve P/N 3102. There was a .028” pinion shim under the inner bearing. I would like to get $55.00 for everything plus the shipping. USPS medium flat rate box to any of the 50 States works perfectly.
Ken
Edison, NJ
Ken
Edison, NJ
