Sean Officer
1967 Dodge Dart 270 2DHT 360 Magnum/A904
Tried something while reassembling the heads on my 273 yesterday and it worked out great. I figure I would share. A bore snake for a .308 Winchester is the perfect size to clean out the valve guides. Just make sure it has copper scrubbers on it. I hosed it with brake cleaner to clean it out, then WD-40 and ran it through a couple of times, working back and forth once the scrubber was through. The scrubber is designed to go through one way so don't try to pull it back through. Leave some slack in the side you are not pulling on to keep the snake expanded in the guide. Now that the valves are installed, they move smooth as butter. I hope this is helpful to someone out there as I have received a ton of help and advice here.
