using a SFI balancer ?
73dart360
fort lauderdale
I put an SFI approved ATi super dampner on ,and it was thicker than stock dampner pushing the pulley too far forward, is there a dampner sfi approved that keeps the crank pulley in stock position ,or a different pulley? can some one please help .
Hi i had the same problem with my damper, I found a slant 6 one belt lower pulley and used a die griner to oval out the one hole, bolted it on. The pulley is off a little bit but i have been running it for 4 years and countless 6500 rpm passes and never lost a belt. Hope this helps.
