V-8 emblem and antenna bezels
momoparman
MOISMYHOME
M I Z Z O U
I have a V8 emblem with two pins that protrude but have been cut. Easy to glue on with a dab of silicone or use 3M adhesive.
$10.00 plus $5.00 S&H
Antenna bezels for a body will clean up real nice with some mothers.
$25.00 plus $5.00 S&H
Mop
I believe that the 67 had 8 notches in the antenna bezel instead of 4. Sedanman is looking for one also for his 67 Valiant.
middle piece is 90099
Outer ring is 292321..1?
the last 1 is spaced away from the other numbers a bit.
Not sure what they came off of...was supposed to be an a body car.
yes you are correct krazykuda 67 bezels have 8 notches not 4. i went and looked at mine and it has 8 notches.thank you,mike.
