Vacuum hose routing for 74 Dart w/ Carter AFB
JGolden
Member
Phoenix, AZ
I'm looking for a diagram for the vacuum hose set up on a 74 Dart with a Carter AFB carb and California emissions if anyone has a link or a picture
................They never came with a carter afb.........they came with the thermoquad.........which is a spread bore carb...............kim...........
I thought the same thing but when I saw that the electric choke present on the carb was not included on the Thermoquad diagrams, I googled the numbers on my carb and it came up as a Carter AFB, not the Carter Thermoquad.
i would bet carter reused the numbers or the data base you got was wrong.
errrggg. can't upload the screen shot showing what carbs where used in
74', but thermo-quad is the only carter 4bbl listed
i'm thinkin' 360 sport was the only dart you'd get a 4bbl on anyway. got some pics?
