buddyralf
I purchased a set of roller rockers (Dove manufacturing) and a new set of pushrods for my 340. It is a hydraulic lifter with adjustable rocker and the pushrods are Comp Cam 7821-16 measuring 7.389" (recomended length)
The problem I measured the pushrod length on TDC #1 using the exhaust valve and saw the recomended length was good. Would the intake valve been different?
Now the pushrods are in, the rockers are in, the motor is at TDC and the valve lash adjustment chart (90 degree method) tell me to adjust #2 intake and #8 exhaust.
The problem, I have no slack. With the adjuster all the way off, the pushrod is tight. All the other pushrods are loose at TDC but #2, #8 are not adjustable at this point.
What happend? It seems the pushrods are too long. Did I measure incorectly?
