Valve Cover Gaskets
racerdude5
Ventura
What are the best valve cover gaskets for a small block Mopar with stamped aftermarket valve covers and factory cast iron heads? What have you guys had the best experience with?
I just use the rubber felpro myself.
Are you evidentially going to ask about every gasket in your engine?
Fel-Pro neoprene rubber gaskets. They work good and are reusable.
Tell the parts guy to look up a 64-67 273 (the years with the solid lifters - so they will get the rubber neoprene gaskets).
Mopar Performance steel core rubber. They are not cheap but they will be the last valve cover gaskets you will buy for that engine. They last forever....unless some dumbass rips them up intentionally.
Dis bees dem rat cheer.
http://www.summitracing.com/parts/dcc-5249581/overview/make/dodge
They are also one of the FEW valve cover gaskets that will seal the old style LA valve covers to Magnum heads.
