Originalowner73 340duster
Doing intake and valve cover gasket..any stuff on valve cover gasket..like rtv or just leave the rubber I think with steel in the middle alone??
I also use 1/4" drive socket and ratchet to lessen the likelihood of overtightening them.i like putting a thin coat of RTV on the inside of the cover, and then put a thin coat of grease on the head
that way, they are reusable
the real trick is to not overtighten the bolts
(in fact, i replace them with studs on all my small blocks, put some locktite on them and use nylocks on top)
New valve covers ..not worried about the reuse part just want it to seal the best!!Make sure rails on valve cover are flat and bolt holes aren't squished in.
Steel or aluminum?New valve covers ..not worried about the reuse part just want it to seal the best!!
And have to drill out also!!Steel or aluminum?
Let's see what you picked junior
Just sucks they don't come pre drilled...Classy, I like em
And are you that old to be calling people junior??? LolSteel or aluminum?
And best seal just leave them an go with it???And are you that old to be calling people junior??? Lol
Just checked your profile page, you actually got a few years on me, sirAnd are you that old to be calling people junior??? Lol
Exactly junior ..RECONIZE....lolJust checked your profile page, you actually got a few years on me, sir
I have about 50k driving the car never had to do anything but clutch..starter..few u joints and swap rear..well and swap the motor with father and uncle when I was like 16..Exactly junior ..RECONIZE....lol
Those seal good, but most likely will need ground to clear the intake manifold.View attachment 1715165150
Is that good??damn heavy tho
