If the springs are "bad" it should be popping back through the carb. Check the end of the rocker arm, and the rocker arm shaft for wear. Could be these 2 aren't oiling through?
if the springs are "bad" it should be popping back through the carb. Check the end of the rocker arm, and the rocker arm shaft for wear. Could be these 2 aren't oiling through?
