VALVE SPRING QUESTION
CFD244
"THE NEW OLDSMOBILES ARE IN EARLY THIS YEAR"
Northern Ontario, Canada
Be careful that the open pressure isnt too high as it may wipe a lobe. Too little seat and you could float.
I noticed heights, spring rates and seat psi are different? Comp has a chart on their site that compares all aspects of their springs.
it's a little more spring than you need but In my opinion it's a pretty good match, but you will have to be careful on the break-in.
I would use a high zinc content break in oil I have had good luck with Valvoline race 30 with a high quality cam break in lubricant I've used lunati . also highly suggest removing the center spring during break-in. I have broken new cams with that spring pressure before without removing the center spring but I can't advise it.
