Mopar Performance Small Block Valve Springs
'Load-Rate'
340 'Stock' {Single-Coil w/Damper}...P/N #4120249
* 90 lbs. .... @ 1.68" {Installed Height}
* 230 lbs. .. @ 1.27" {Valve Open}
340 'Extra High Performance' {Single-Coil w/Damper}...P/N #5249847
* 103 lbs. .. @ 1.68" {Installed Height}
* 260 lbs. .. @ 1.20" {Valve Open}
340 'Street/Strip' {Dual Springs}...P/N #3614542
* 110 lbs. .. @ 1.68" {Installed Height}
* 295 lbs. .. @ 1.18" {Valve Open}
340 'Radical Street' {Dual Springs}...P/N #3412068
* 135 lbs. .. @ 1.68" {Installed Height}
* 325 lbs. .. @ 1.16" {Valve Open}
Original 1968 Literature
340 'Stock' {Single Coil w/Damper} 'Factory Load-Rate'
* 134 lbs. .. @ 1.68" {Installed Height}
* 245 lbs. .. @ 1.25" {Valve Open}
'Load-Rate'
