Valve springs
I like to run the springs the cam supplier recommends. Not sure if it would be a deal breaker, but more then enough is not always good either. But really need more info. Roller, flat tappet? It's easier to get the recommended springs/retainers, set them up, and run with it if you can work it out with the installed height.
Trick flows, spec. 120 [email protected]" installed height
394 lbs. @ 2.175" open
390 lbs. per inch rate
lunati cam spec. lift@valve .494 in. .513 ex.
only thing I can find on their site, with their recommended spring package is dual springs,
333 lbs./in. spring rate
Thanks fella
oh and hyd. flat tappet
Look in the Lunati catalog. It has all the info there.
#73100 spring
125 @ 1.850
325 @ 1.25 open load
1.110 coil bind
333 rate
Over the nose, you are going to have about 315 with the trick flows and 290 with Lunatis recommended.
#73100 spring
125 @ 1.850
1.110 coil bind
333 rate
So the trick flows are too much right?
thanks cracked.
so close yet so far.
Since they`re both dual spring, is it feasible to just replace the inner spring? with a lighter rate, or would I need to buy the proper dual springs and retainers?
