Valvebody help
CLAY72dart
Summerville South Carolina
Please help me I’m trying to rebuild this valvebody and I have a extra not supposed to be extra spring. Its the same as the other larger spring pictured I have searched the Tom hand and another book and can’t find where it goes.
My Transgo TF1 kit had me replace a single spring with a double spring for the Line pressure valve. Maybe someone has been in there before you? Sorry I couldn't be of more help.
Thats what I thought the spare was.
Do they look to be the same thickness of wire?
Maybe one is heavier/ lighter,
You said the springs are the same with vernier callipers?
I didn’t use a vernier caliper I just eyeballed it and they look to be the exact same, but where else would it go? There is nothing else on the trans with this type of spring. I’m wondering if the previous rebuilder put one inside of the accumulator because I’m almost certain I took one out and it was filled with crud.
