[FOR SALE] Various engine parts
go-fish
MSD Blaster coil - $20
Holley Street Avenger 670 cfm - $200
Carb Spacer $15
Edelbrock Valve Covers - $15
Various Mopar Logo bolts - $15
Chrome Dipstick - $5
Trans crossmember - $50
NEW 90* oil filter adapter - $75
LA Tube and Peen P4120603 - $60
LA Lifter Bore Burnisher .906" - $50
Oil Pressure Relief Spring - $5
MSD 6 AL Box $175. (((( sold ))))
Accel 8.8 Ferro-spiral race spark plug wires $10 (((( sold ))))
Edelbrock Performer RPM intake $100 (((( sold ))))
Flow Kooler water pump $50 (((( sold ))))
Milodon Windage tray $50 (((( sold ))))
Milodon Windage tray stud kit $50 (((( sold ))))
Alternator $50 (((( sold ))))
Chrome water neck. $10 (((( sold ))))
Timing chain tensioner $25 (((( sold ))))
Sway Bar $65 (((( Pending ))))
Intake Bolt set 12 point $10 (((( sold ))))
LA mopar distributor bushing $5 (((( sold ))))
Cloyes timing chain $40 (((( sold ))))
Dist. Bushing installer. $75 (((( sold ))))
Clutch/ brake pedal assem. $200 (((( Pending ))))
Mini-Starter. $40 (((( sold ))))
MSD Spark Plug Wire Set $15 (((( sold ))))
LA Crank and Water Pump Pulley $50 (((( Pending ))))
I’ll be at Fall Fling in Van Nuys, CA on Oct. 26. I would deliver the parts there no charge. I’ll also deliver anywhere in San Diego county for no charge if it’s more than one item. Other than that shipping will be from 92118 if you want
John
I'll take the windage tray, water pump, msd sparkplug wires, distributor bushing, and timing chain (if new)
Your inbox is full.
I'll take if still available:
- Accel 8.8 Ferro-spiral race spark plug wires $20
- Edelbrock Performer RPM intake $100
- Flow Kooler water pump $50
- Alternator $50
- Chrome water neck. $10
- Timing chain tensioner $25
- Intake Bolt set 12 point $10
- Cloyes timing chain $40
- Mini-Starter. $40
Interested in the swaybar. What was it removed from and shipping to 04240. Thanks
The swaybar was removed from an A-body. It came with my car (1969 Valiant) in the trunk. My car was swapped to a 73+ k-frame though. This will not fit cars prior to 1973. 1967-1972 A-body k-frames.
Shipping cost to 04240?
In the first picture, next to trans crossmember, is that a radiator support brace? Interested in that and the accel wires.
Update on the parts in the first post
