[FOR SALE] Garage clean out sale
RussellSullivan
East Liverpool, OH
Something I thought I'd never do is abandon my automotive hobby. Nevertheless, I'm trying to downsize my possessions overall, get ready to sell my house, and pursue blacksmithing as my main hobby. I still have some stuff to dig out and list for sale, but this is the bulk of it. I can provide better photos upon request, measurements, etc. All prices are plus shipping, unless noted "Pickup only."
1) $200 318 engine from 1989 Fifth Avenue. Complete, but partially disassembled. Was a running engine when pulled, still turns over by hand. I do have the cylinder heads, int/exh manifolds, valve covers, rockers/shafts/pushrods, they are just off the engine. Pickup only
2) $100 8 3/4 housing and axles. Housing is believed to be from mid 60s Belvedere.
Flange to flange 54 1/4"
Spring perch, center to center 36"
Axle shafts 30 splines, flange to end of splines 29"
Pickup only
3) $50 Instrument cluster from 1963 Chrysler Imperial
4) $20 M body air shocks. I believe one is good and the other is bad.
5) SOLD
King engine bearings for small block. PN# CR 805SI 010. One full set, one partial set.
6) $20 M body ISO shock plate set
7) 904/998/999 transmission mount. Rubber is shot. Free to good home, pending background check.
8) $20/ea Small block flexplates
9) $40 Plymouth wheel covers, 14" driver quality
10) $20 Driveshaft from 1980 Dodge Diplomat. Rear flange to end of yoke 58" Pickup only
11) $10/ea Fuel pumps. One for slant six, and one for small block
12) $10 Fuel sending unit for M body. Unknown condition
13) $5 Ground straps. One single and one double.
14) $10/ea Alternator, PS pump, starter. All should be treated as cores, as I've forgotten which ones are good.
15) $20/ea Clutch fan and fiberglass fan. Clutch fan from 1989 Fifth Avenue, fiberglass fan unknown, slotted holes for various applications.
16) SOLD
Various spark plug wires. Roughly two sets. PN# 27604
17) $10 Vacuum lines, fittings from 1989 Fifth Avenue
18) SOLD
Timing cover, two random brackets and two random pulleys, Fuel pump. Appears to all be small block Chrysler, they were here when I moved in. Price is for all.
19) $20 Radiator from 1980 Diplomat, slant six. No leaks.
Also for sale is a Remington chainsaw. Worked fine for awhile, until I bought a Stihl. Couldn't get it running this year, likely due to poor maintenance. $50 Pickup only.
I'd take the rad and shroud if I knew where to pick them up. Oh. East Liverpool. OH? Ouch. I'll pass. Sorry
Shipping will kill it for me nowadays, they should sell locally. Thanks for the offer though!
If you decide to part out the engine, what would you have to have for the lifters, dogbones, spider, and the bolts?
