There is a small difference. One of the attaching points of the "A" post assy is a small screw/allen accessed through the sheet metal and covered by a small rubber plug. The location of this hole is different in 1967, '68/69 are the same. If you have a '68, it will be easier for you to locate a '68/'69 assembly.
