vin check
Floorman
My brother in law is looking at a 76 Duster and was wondering if someone could decode it for him.The vin is VL29L6G157659.The guy that has it says it is 1 of 400 and we just want to make sure of this.
Thanks
Did you see the mopar vin decoder at the top of the page? :) Ah, never mind, it only goes to 74. Do you have any fender tag info?
Really the burden of proof is on him, does he have any documentation from Galen Govier for example?
this is what I came up with...soemthing doesn't look right though...either the site I used or the VIN.
http://www.stockmopar.com/mopar-vin-decoder.php
Body Type: V = Plymouth Valiant / Duster
Price Class: L = Low
Body Type: 29 = 2 Door Sports Hardtop
Engine: L = Unkown
Year: 6 = 1966
Sequence Number: 157659 = 57659th Vehical Built
found another site.
http://www.jonsteiger.com/WWW/moparvin/
The Vehicle Identification Number VL29L6G157659 is from a 1976 Plymouth Valiant (2 door special coupe, in the Low price class). It ws built with a 360ci V8 4bbl HP (LA motor) engine at the St. Louis, MO assembly plant (build sequence number 157659).
VIN VL29L6G157659 decodes as follows:
Description Interpretation Code
Model: Plymouth Valiant V
Price Class: Low L
Body Type: 2 door special coupe 29
Engine: 360ci V8 4bbl HP (LA motor) L
Year: 1976 6
Assembly Plant: St. Louis, MO G
Sequence Number: 157659 157659
Thanks I will pass it on.I had him sign up tonite as well.We can get the fender tag info tomorrow.
Fender tag info
N21 N38 N41 26A0
F18 G01 G54 G64 G74 J52
TX9 C A88 841 C16 C56
TX9 C9X9 000 C02 838825
E58 D36 VL29 L6G 157659
Thanks for the help.
