Vinyl Top Cleaning????
moparguy1967
I had never stored my car under a cover before this winter. The other day I took the cover off and the top has white streaks. I tried the cleaner conditioner that I have always used, but it did not do much. Any ideas.
Probably some kind of moisture damage. I don't think you can clean that.
You may need to re dye the top (may be the only option other than replacement to get even color back).
I would need to see it in person really....
If you have just uncovered it, let it sit in the sun for a bit.
And never use a cover that does not 'breathe'.
What kind of a shop will do a re dye job?
