I just picked up another 1972 Duster. 318/904. This is a project someone started some time ago. Bottom side is really solid. The body work was started on it and has some work already dome. Floor pans are solid. Comes with a new spare tire well that needs to be installed. Rest of the trunk is solid thou it needs some work done still by the tail panel at the floor. Someone along the line has install a 73 or new Spool K member. Has lower A arms with the sway bar tabs but no sway bar. Some sort of aftermarket Strut rods and large bolt pattern disc brakes. It appears that all the front suspension has been replaced with new parts including the LBJ A arms. Has 340 892/893 torsion bars. This was a 318 floor shift 904. Includes the console. Along the way the rear end was replaced with a BBP 71/4" Rear end. Has a 67 date cast 318 short block in the car that was rebuilt at some time. It has .030 pistons in it. I got a bunch of paper work with it so I'm going to attempt to get a tittle in my name. Great hood and deck lid. Solid doors with glass but are 73 or newer. This is about all I know as far as information on this car. Great project or for building a bracket car. Includes everything in the pictures. Also a floor shift column. Or if I can't get a tittle I will be parting it out. $2000.00 as is what you see is what you get. Plus the tittle fees if I can get one.
