69dodgedart360
hey everybody, i have a problem that i cant seem to figure out. when i am cruising (anything over 1500rpm) the voltage gauge reads its putting out 15volts, but as soon as i come to a stop, it immediately drops to 13v which is fine but the problem is sometimes (because this is an intermittent problem) stoplight to stoplight, it will drop real low to 12-11volts for some reason and i am forced to throw it in neutral and give it gas or manually shift the car so it wont die out because it starts to idle really rough. It also makes the car hard to start after i park it while i am having these problems. This has been going on for a long time, I have changed two alternators, three voltage regulators, a ballast resistor, a coil, and checked the grounds. everything that i think i should check i have and the most frustrating thing is that somedays its ok but other days it does this to me.
HELP!
P.S. this has happend with my old factory guage set-up and new set-up. if it helps i just ditched all of the factory guages and put in electrical auto meter sport comp 2's
HELP!
