Today i noticed my volt gauage was getting pretty close to pegging so i grabbed my charging system analyzer wich is a belden and hooked up to a ground and to altenator output charging wire with the hedalights on dim and number 2 light lit up and stayed lit up. I read the back and it says if light 2 is on the battery is good but its not charging and it says field/regulator open. What can cause this? is my altenator toast and sending to much voltage to the voltage regulator? I dont understand because it says battery is still good but field/regulator is open. I have another voltage regulator plus a life time warranty on the regulator i have and i can put a new regultor on and it will be fine for about a month and eventually they will fry this is the second time this has happened. The altenator i got brand new but i had the regulator wired wrong when i installed the altenator and quickly figured it out and got it wired up correctly. So is there a chance my altenator got ruined during the short time my voltage regulator wasnt wired up right and now its frying any voltage regulator i put on after a few weeks? Thats the only thing i can think of my field wires are wired up correctly and my altenator charging wire goes straight to the starter seloniod and on to the battery.
