mod5v
I had this cam in my D150 until I pulled the motor for my dirt car. Has maybe 5K miles on it. in Perfect used condition. All lifters labeled for position. So it is already broken in for you. Great cam for a 273/318 street cruiser.
#60400lk or the new number is 10200700lk
Hydraulic Flat Tappet Cam. Very strong torque and increased HP for small cubic inch motors (273-360). Compatible with stock type fuel injection. Works great for pleasure/ski boats and mild towing applications.
•Advertised Duration (Int/Exh): 250/256
•Duration @ .050 (Int/Exh): 208/213
•Gross Valve Lift (Int/Exh): .454/.454
•LSA/ICL: 112/108
•Valve Lash (Int/Exh): Hyd/Hyd
•RPM Range: idle-5000
asking 125$ shipped in the lower 48 .
•LSA/ICL: 112/108
