tblotske
Have a full set up others then valve guilds and rockers . W9 heads intake with spacers so you can use either block low or high deck. TI valves and keepers springs like I said these haven't been touched the seats sent installed you can build them the way you like from what I was told sence no porting other then factory these could be made to work on both lifter degree blocks by Ryan at shady. There in Bicmarck nd looking to get 1500+ shipping I'm getting out of small block and going hemi so selling all my stuff have steel crank for 340 $150also and new roller lifters and oil pump shaft with bronze gear $550 all plus shipping .
