Want flat hood for 67 Notch!!!
DesertRat
Leading edge boomer
Moses Lake, Washington
Can anyone tell me with difinitive authority what flat hood will interchange with the bumped hood on the 67 barracuda's? I don't want to reinstall my stock hood and I am looking for alternatives, close guesses won't do as cash will be changing hands and well------------------you know------------
TIa, RAt
... it has a little peak at the center front that will look silly (the 67 nose piece doesn't have the matching peak -- it's straight across, as you know). If it was fiberglass you could just grind it off, though. Here's a photo of a 69 Barracuda to see what I mean.
http://www.markheim.net/spring05/pages/PICT0022.html
By the way, this is also interchangeable with a 73-76 Dart hood, but you might have to adjust the hinge bolt holes.
Oh, I just looked at the photo of the AAR hood -- yes, a 69 Barracuda hood is exactly what that is. They are correct in that it fits a 67-68, they just don't mention that it will look silly at the center front unless you can get rid of that peak, or swap in a 69 nose piece (with the much rarer and more expensive 69 grilles, I might add).
TIa, RAt
for a 67 interchange is 67 and 68 hoods only. fastback, notch and conv. are the same.
You could use a 69 hood if you also use the 69 header panel and and grills.
