Backtobasics
WHO: My contact info: [email protected] Zach Myers 913-708-4811 Cell
WHAT: I need a 1 bbl for my /6 Dart.
WHEN: Sooner then later
WHERE: Kansas City
WHY: I have rebuilt the carb I have, but it never had an acc pump rod. I fashioned a rod, and it worked, I had acc pump charge again, but at same time, it stalled, and would only run on acc pump charge. I figured the idle circuit picked up some gunk so it would not idle. I took it apart, clean everything, but in the process broke the emulsion tube. I had fuel tank issues and vent issues earlier, plus a clogged filter, so chance that something clogged the idle circuit is likely cause of no idle.
I need a cheapo carb that I can throw a kit in and drive. My DD Ram has started knocking (mains) so I need the Dart to run for a bit while I rebuild the magnum motor in the Ram.
THANKS!!!
WHERE: Kansas City
THANKS!!!
