Wanted: 318 PS bracket
scamp80602
Life Long MOPAR Man
North Metro Denver
Rating - 0%
0   0   0
I have a 75 318 Scamp with CA emissions - smog pump. I'm wanting to remove the smog pump and replace the current high mount PS bracket - it mounts the PS pump above the smog pump - with the standard low mount bracket that mounts the PS pump where the smog pump is now. I'm looking for the low mount PS bracket. Thanks!
Thanks PlumCrazyDuster, I'm all set - found new reproduction brackets on ebay for about $65 shipping included. I think I'll go with those. I didn'r realize they were so available.
Do you realize the pulleys are different as well? I believe the belts are located further away from the engine with the "high mount" power steering.
Thanks for the tip 340duster, I didn't know the pulley's were different. Maybe my best bet is to buy a used PS pump with pulley. My current pump looks different than either of the pumps in the service manual. The mounting is also way different. I may be best off with the "ham can" Saganaw unit.
