[WANTED] Wanted 9” drum front brake spindle nut washers
Is it the right size. I looked based on 67 barracuda with 273. There was no mention of brake size
What size dia is your spindle. Look at 65 mustang, 6 cyl has small drums
There you go that’s a better deal. Mine are for the smaller 9” drums from a /6 barracuda if you have the larger 10” drum you might need the larger washer not sure if there the same.
