WANTED: a single 1.6 ratio Hughes Small Block Roller lifter
Dave, do you know anyone who has a 1.5 roller rocker? You could compare it against your 1.6 from Hughes and if yours is truly a 1.6 ratio, you would easily see the difference in the adjusting screw location between the two. Just a suggestion. It doesn't need to be a Hughes rocker to compare it to.
