[WANTED] Wanted (can pick up in Carlisle): body parts
tom999w
New York
Rating - 0%
0   0   0
Wanted (for a '71 Demon or equivalent car, used or new):
1) drivers side full length rocker (inner and outer)
2) bottom half of firewall
3) full floor (auto on column, no manual trans hump holes)
4) both front frame rails
When you get to Carlisle, go straight to the Stephens Performance tent. You should be able to buy all of that new, from Ted.
Thanks for the info. Used parts are preferred, to keep costs down. This car is a budget build. Thanks.
Sometimes the labor to repair used parts from the years of service will far exceed an aftermarket part that will require some fitting or minor adjustments.
I would recommend going to check out @davescuda he has a few spots in row N directly behind Coker tire's big trailer.
hes bringing A-body sheetmetal....some new in the AMD box and some NOS pieces....
Parts are out there just gotta pony up for them or accept in less than favorable conditions.. I've got a few lines on most everything your looking for, but to be really honest guys have offered within 2 hours drive and you haven't moved..
I will have the inner rocker, way cheaper than Stephen‘s performance
I haven't moved because I am NOT cutting sheetmetal parts off of someone else's car. That's a recipe for disaster. If those people have the parts already off the car then I'll gladly stroll by and pick them up, but they don't. Carlisle would be fun to visit anyway (never been there)...
If you see what it takes to remove a frame rail from an a body you will realize why they charge what they do when they have the old used one over there all Swiss cheese out....plug welds the size of m&m's
Peanut or chocolate M&M's? :lol:
