Wanted Custom Dash For 68 Dart
ive already got the custom door panels underway,im moving to the dash next,but what i make will be total custom,hotrod style,with a digital cluster that goes black when turned off. http://store.summitracing.com/partd...002R&N=700+4294925228+400187+115&autoview=sku this is what i plan to use,because they offer different colors,reb,blue,grenn,amber,to go with different body/interior colors.Also,with what im making,the factory heater/ac controls wont be used.It will prob be more radical than what most people here will want.
What are you working on Toby? I've been working on a coming up with a design to retro that same digital display into my dash but keep running into the heater controls and not knowing what to do with them. I'll be adding AC and have found kits to use existing controls but haven't found alternative control options yet. Care to share what you've got?
I need a custom dash for a 68 dart .... please let me know if you have something or know where I Can get one
sayler@bresnan.net
This guy is coming out with a line of Mopar custom dashes. Just not on his website yet.
He will be displaying at the Fall Fling Mopar show here in Van Nuys this Saturday in the vendor midway. I'll try to remembmer to take some pics of his work. Hopefully some others will do the same.
http://www.covansthunderroad.com/
Do you know anything about what he has coming out? Years, models?
You could always make your own. It took me sometime to do it, but you can make it the way you want it.
Make your own. In the end you have something that is the way you like it rather than what someone else thinks you should like.
Larry
Haven't found anyhthing yet... I emailed a few of the suggestions but haven't gotten any response
Most of their stuff is made for early fords and chevies. You could probably make one work with alot of time and effort. If you have a sheet metal fab shop in your area they can bent up aluminum and mig it together so it fits into the dash. Here is a couple of pics of mine. Only thing is, I cut my dash and made the panel longer on the right side. The last one is with it installed (missing speedo at the time).
Larry
