Wanted: Does anyone know of someone who can rebuild dashboard to original?
CudaBrain
Active Member
Denver, CO
Hey folks...so the guys at Reincarnation Auto in Colorado Springs really did a number on my 1966 Barracuda. They shorted out most of the dash and most of the gauges don't work. Also the vacuum gauge does not work. The guys trying to undo the damage don't have the knowledge to fix the dash. Anyone know a shop that repairs/rebuilds Mopar dashes (correctly)?
There are several. We use Red Line Gauge Works for the last 20+ years
Shannon Hudson is a Mopar guy.
They probably shorted out the instrument voltage limiter. Which possibly took out one more gauge. Vacuum gauge ? Hook up vacuum . Disconnect the battery and pull the cluster. What kind of car?
I used instrumant Specialties. Not Cheap!!
If you need a good used instrument cluster with working gauges, I can probably help you depending on options desired. 120 speedo and vacuum gauge should be no problem. 150 and tach might be.....I'd have to check. The face plate will need refinishing for show.
I did the cluster over on the wife's 65 Dart. Electronic IVR I even swapped the gauge faces from a round temp and fuel gauge I had for the square ones In the Dart.
JC Auto Restoration in Lynwood WA specializes in Mopar dash restoration
