[WANTED] WANTED - Slant Six windage tray bolts
halfafish
Damn those rabbits, and their holes!
SW Washington
I have a tray, but I still need the special bolts that hold the main caps in place, then have the additional threaded tops for the tray. Does anyone have a set, or know where I can get some? Google-searching isn't getting me anywhere for these bolts.
In my under construction slant I used LA windage tray bolts. I found that the LA bolts were too long and would cut off the oil flow in the oil channel under 1 of the bolts (per an article over at .org) so I had them shortened to slant length. Then when comparing the thread length between the two, the LA bolt threads needed to be extended to the same thread length as the slant main cap bolts. A little work but it works. You might try drilling and tapping a slant main cap fora 1.4 in bolt as well.
